Caluser2000
Banned
Got my Hdd update for my Redstone ready to go. Locally made XT-IDE card, 2.1 BigFoot drive with ribbon cable. The original MFM hdd was dead when I got it a while ago. Long over due for replacement. The BigFoot should be ample storage. If that goes tits up I have plenty of replacement drives. It has a EGA monitor and video card so was worth keeping. Interesting that it came with two manuals. Usually they're the first things to get lost. Came with a 360k 5.25" A: drive and 720k 3.5" B: drive. I already had a high density 8-bit ISA fdd card stripped from another system. Removed the original fdd controller and replaced it with the HD one. Pulled the 360k drive and fitted a beige 1.2meg fdd so it currently boots to HD media. Currently I have DRDos 6 and MS Dos boot disks in that format. Haven't decided which I'll install yet. At one time I had tons of software on 5.25" media but I lent them out and never got them back. I've got an Amstrad Adlib clone or Media Vision Thunderboard sound card I could fit to it. Have some odd looking serial mice that wouldn't look out of place.
Other than the above a few updates could be on the cards. A V20 cpu, an 8-bit NIC with RJ45 ethernet port and math co-pro come to mind just because. Might swap the beige fdd with a black one which came out of a 286 I found while having a clean up. Software wise other than Dos I'll put on XTree Gold and Checkit for sure. A computer with a colour monitor cannot go without having some sort of Graphical User Interface so I'll throw GeoWorks Ensemble Pro 1.2 on just for giggles. It'll look dandy in 16 colours. mTCP will go in once I acquire a suitable NIC. Of course I can also add an external BackPack parallel port CDRom drive if I needed to.
