RetroSpector78
Hi, I've got an 8 bit WD1004-27X hard disk controller.
According to the documentation :
So I am a bit confused if this controller is in fact MFM or RLL
Now, I tried formatting my 21MB MFM drive with it (and with some other cards), and here are the results
Now if the WD1004-27X is indeed RLL, I would have expected the total disk space to be around 31MB, as during the LLF, I specified 616 cylinders and 4 heads.
On the other hand, I also notice the WD1004-27X reporting the same amount of bad sectors as the ACB-2072.
Leading me to my questions
The WD1004-27X and WD1004A-27X boards work with any hard disk drive that has the ST506/412 drive interface and no more than 1024 cylinders and 16 heads.
The Seagate 238 hard disk drive unit is such a drive.
Look in your drive manual to verify that you have an ST506/412 RLL drive or check with your dealer.
This board does not work with RLL drives. If you have an MFM drive you need either the WDXT–GEN2 or WD1004A–WX1 board.
- ST506/412 : could mean both MFM and RLL
- Seagate 238 : Seems to indicate RLL
- verify that you have an ST506/412 RLL drive : Seems to indicate RLL
- This board does not work with RLL drives : typo ?
- If you have an MFM drive you need either the WDXT–GEN2 or WD1004A–WX1 board : Seems to indicate RLL
- WD1004-27X (RLL?) : 21.344.256 bytes of total disk space and 28.672 bytes of bad sectors
- WD1002 MFM: 21.204.992 bytes of total disk space and 0 bytes bad sectors
- ST11 MFM : 21.274.624 bytes of total disk space and 0 bytes bad sectors
- Adaptec ACB-2072 RLL : 31.203.328 bytes of total disk space and 28.672 bytes of bad sectors
- Is the WD1004-27X MFM or RLL ?
- If the WD1004-27X it is RLL, did it format it using 17 sectors / track, leaving the "other" 10MB unformatted ? And if so, what is the point of encoding with RLL and only using 17 sectors / track ?
- Are the bad sectors using the WD1004-27X and the Adaptec ACB-2072 the result of using RLL encoding on an MFM drive ?
