labspencer
Hi
hope someone can help me if they've had any experience with the DFI AT-Rambank 2MB expansion memory board
this pic is from minuszerordegrees.net but mine is identical rev 7 mode. maybe foolishly I bought 2 boards untested off the bay recently to get setup on an IBM 5170 AT motherboard I have. This motherboard with 512k works fine and tests out ok. the motherboard revision seems to be the 3rd and final one, at least it has 80286-8 mhz cpu and 16mhz clock, and latest IBM bios roms, although strangely it does have the u131 shunt block which is supposed to be hardwired and it doesn't have the usual serial number.
anyhow here's my problem, both the AT-Rambank boards refuse to work and stop the computer booting up, the power supply starts up but nothing appears on the screen, probably no video signal as the monitor stays in standby, not even the usual Ram post count to 512k, it just hangs. I've read through the manual and believe I've got the settings right, checked out all the ram individually (stripped it down to just Bank 0), tried different slots but no joy
Does anyone know if this board is compatible with the later 5170 motherboard, I have searched this forum and read some posts from members who have got it working with earlier motherboards but so far nothing i can find on later one. If it is known to be compatible could anyone suggest a remedy I could take, how about suspect capacitors on the board, they all look ok but I know from rebuilding a 5160 they can prevent things working as they should? I don't want to start hacking at it if it ain't going to work.
any help/info/suggestion appreciated, otherwise these boards will be back on the bay
thanks
thanks
