cb88
So The bootrom does load so I do have a BIOS that can load roms... so that isn't it. The Inboard was in it when I got it and it requires a bootrom IIRC anyway...so yeah.
The XTIDE Universal BIOS says... No master and no slave found. So it seems it can't see the card?
I installed DOS to the CF card I have which is a Sandisk SDCFHS-016G-AFFP
QEMU can boot from the drive when connected to a CF to USB adapter. I setup the drive under Linux with QEMU as that seemed much less problematic than windows getting in my way every turn. I installed from the DOS 6.22 floppy images in QEMU with the CF disk also mapped into QEMU, rebooted and did fdisk /mbr and QEMU was then able to boot directly from it.
Any ideas?
I tried basically all jumper settings on the XT-CF lite board to no effect. Note this is the red XT-CF lite from texelec. I'm leaning toward this being just the card isn't compatible but wanted to see what others think.
Any ideas?
