FiveGHz
Hi all, I recently came across an IBM 5150 on the side of the road in pretty decent condition. I took it apart to inspect the components before powering it up, and I found a burnt trace on the CGA card. I used a multi-meter to test for continuity, and the trace definitely is cut. It seems to be connected to one or two of the actual pins on the connection to the monitor. I don’t have a lot of experience with this stuff, but was wondering if it would be safe to just add a jumper wire around the cut, or if there is something else I should be concerned about.
Any insight is appreciated.
Thank you.
Thank you.
