I would like to upgrade the graphics adapter in my IBM 5160 which is currently an IBM MDA connected to an IBM 5151.
I have tried an IBM CGA adapter connected to an IBM 5153 but the text mode blinks when scrolling and the characters look ugly/blury compared to the MDA setup.
Am I right in thinking that a better solution would be to use an EGA card that emulates the MDA and CGA modes (not 100%) via DIP switches accessible from the rear bracket?
I could then use either an IBM 5151, IBM 5153 or IBM 5154 monitor by simply changing the DIP switches on the EGA card.
I could even use a more modern VGA CRT / flat panel with a MDA/CGA/EGA to VGA converter and set the EGA card DIP switches to whatever I like.
These are the MDA/CGA/EGA to VGA converters I have found:
EternalCRT - MDA/CGA/EGA to VGA Converter Box
MCE2VGA - CGA/EGA/Hercules/MDA to VGA Converter
These are the EGA cards I have found:
IBM EGA Graphics Adapter Card without daughter expansion card
AST-3G Plus EGA videocard ISA 202104-001 256K IBM AT XT
STB EGA Multi Res 8-Bit ISA Video Card
Which of the converters would be better? (I'm thinking about the EternalCRT but it's out of stock at the moment)
Which of the EGA cards would be better? (Maybe something else?)
Thank you.
Thank you.
