I took pictures, but now I'm not sure what exactly it is that I have. The case this board was in has a '339' sticker, which as far as I know means it's an 8MHz model. But it's very clearly a 6MHz system. Also, it has a "TEST 339" sticker on the back with a barcode (in addition to the 'normal' barcode sticker). Maybe this board was originally from another system and got transplanted into this case? I really don't know.
Regarding the motherboard itself. I think that it is a type 2, because of the
combination of what I see:
* Smaller form motherboard.
* Lack of a "FRU-6489922" sticker.
* 12 MHz crystal.
* 6 MHz CPU.
* ROM set 6448896/6448897, a set that is only one digit off the 6448894/6448895 set shown in figure 9 of [
here]; 6448894/6448895 indicated as fitted to a model 239.
* Presence of a soldered-on U131 jumper block (although I was sure they were only on type 1 motherboards).
What date is in the code of the 6448896/6448897 ROM set ?
Any 1986 dated chips on the motherboard ?
Out of interest, is the 82284 chip a 82284-6 or 82284-8 ?
Out of interest, is the 82288 chip a 82288-6 or 82288-8 ?
(I used to have a type 2 motherboard many many years ago, but sold it.)
