Bmurching
I am slowly trying to restore a Compaq Deskpro XT. It was in rough shape but I am slowly making progress. It’s a 640k 20MB dual 360k floppy model running a 2/27/87 BIOS. Current status: I can boot off one of the 360k floppy drives to DOS without issue. The other is not working, nor is the HDD.
The current issue: when I start up Spinrite 5.0 in hopes of studying the HDD issue, it goes through a startup memory test and consistently freezes during the test, at test 321, buffer FF09h (on data pattern 1000 0000 0000 0001, FWIW). Not sure if this relates to a specific RAM chip.
I’ve run CheckIt’s thorough RAM test multiple times as well as the Compaq diagnostics and it passes every time. I am starting to think this might be a spinrite issue. Any ideas?
Oh— I’m booting into DOS 3.30 before starting spinrite. I’ll try 5.0 as well.
