deanimator
Hi everyone,
For the benefit of other fans of vintage x86 machines, I've developed a ROM code that enables you to boot from a parallel port, by means of a cross-over parallel cable and a machine that provides a bootable image (currently DOS or Windows). I use this in my 5150, if there's no bootable drive before the ROM-BASIC loads. But it can also be used in other, "more modern" x86 systems, e.g. when placed inside the BIOS, or in a boot ROM socket of a network card etc.
And, if there's anyone that'd like to breathe in some life into the cassette port of a 5150 or a PCjr, I came up with a small application interface that can be used inside PC-DOS or MS-DOS to access the tape from there, since DOS had no native support for this. Ofc you don't need to use a tape recorder; any audio device with a mic or line-in and a PC with DOS shall work.
Both of these experimental apps are released as open source.
Comments, hints and suggestions appreciated.
Regards
Regards
