maxtherabbit
Note: this is not the infamous false positive checkit test! My EGA has the daughterboard and full 256kB fitted. That said, I'm fairly sure the error is in one of the chips soldered to the card. I could simply desolder them all and replace, but 8 DIP-18s would be a bit tedious.
Errors will occasionally manifest in visible text mode corruption, usually from a cold start and will go away very quickly. Very occasionally I can get the checkit video memory test to fail, but 99% of the time it passes. I have yet to be able to catch a failure with the IBM diags disk. Attached are two examples of the failing bits reported by checkit. If anyone can help me narrow this down to an IC, or even bank of ICs on the EGA itself, I'd be quite grateful.
