So you read the stencil in columns of 2, not rows of 8.
Thanks
I'm working on a 5162. I use the IBM Diagnostic Disk for AT's to set the floppy's.They are set to the same as the jumpers on the card. Should they be at null/nothing?
(I also get the same 1782 error for all of the five different HD cards I installed)
I had to put in a different FD card. The above card would let the system boot from FD. It went to Basic.
5170 Diagnostics Setup, a Gsetup will not allow, FD 1 to be set to null, only 360K and higher. FD is set to null.
Is there a link to ImageDisk. Google is not alot of help with those generic terms.
Thanks
