MauriceH
Have a IBM XT 5160 with the IBM 20MB WD25 MFM hard drive.
AT start up no spin or light from the drive, only after some seconds the click from the Head block brake.
Checked the PCB for common failures as traces, Power resistors, power transistor capacitors and relays contacts.
Also the relay is powered by start up.
Then suddenly at a stand alone power up (5V and 12V on the connector) it started to spin again.
Put back in the XT and it ran perfectly the whole evening without a failure.
Next day, dead again, no spin.Also no seek of heads.
Try to figure out if the Hard disk could spin up only through a voltage on the power plug, or
does it get a control start from the MFM driver board?
The MFM driver card is the IBM 62X0776 that came with the drive.
Maurice
Maurice
