Hi,
I am trying to fix a Seagate ST-225 type 2 hard drive. It is a 20 MB drive. The controller is 62X0775 with 4 switches.
Problem: the drive is reported by the BIOS, but programs can not use it. Programs report problem with MBR.
The BIOS does not report 1701 error. It reports a 601 floppy errror, but the floppy works.
Switches on the controller are correct. Cable is OK. I tried LLF:
- debug - it returned immediately with some result, so it did not have any effect
- IBM Advanced Diagnostics Disk - gives an error and it returns immediately
What I noticed is that the stepper motor only turns on power on with a beep and when using the "Measurements Test" in the IBM Advanced Diagnostics Disk. Nothing else makes it move. Programs like fdisk.exe and part.exe do nothing.
It seems like INT 13 is not handled ... Not sure where the problem is ... the HDD or the controller.
