Jotschi
Hello,
I just started my second IBM PC restoration project.
The 5150 has a 130W T2.0A 250V PSU which is not working. I tested it without the FAN and only a dummy HDD attached.
I can hear a relay trip and I get no power on the plugs. I assume this is the over current protection circuit kicking in.
I also tested this without any load attached. When the fan is attached it gets a small amount of power and moves a bit. (no full rotation).
I have also found some documentation on the PSU:
http://worldphaco.com/uploads/The_IBM_5155_POWER_SUPPLY.pdf
On the bottom I noticed a cut in the ground plane. Is this a known bodge?
I checked the PSU pins with no mains power and loads connected and noticed a low resistance between 12V and GND. (24Ohm).
Is this normal or does this indicate a problem? I noticed a 24Ohm resistor on the board. I suspect this to be a bleeder resistor.
Is the board with the relay part of the over current protection circuit?
I know that PSU repairs are hard and I don't have experience in this but I still want to give it a try.
Any hints or tips would be welcome.
