I don't think i'm properly creating the files needed for the IBM 5150 to run off the Gotek floppy drive emulator. I'm running flashfloppy and i've grabbed DOS v1.10 from this website.
https://winworldpc.com/product/pc-dos/1x
I used the hxC floppy Emulator software to convert my IMD to a HFE file and put it into the root of my directory of my USB drive. The Gotek can read the file because i don't get a F-F error and i can circle through the images i have on the card.
But when i boot up the computer and hit Ctrl + Alt + Del i don't think it reads anything because the screen just blinks and returns back the basic prompt. I also don't see the green light turn on ever.
I'm guessing i have it wired up. I have S1 jumper on, JC jumper on and i'm connecting it with a old 5.25 drive cable that has the 3.5 drive cable inline. I had to cut the bottom part of the connector to make the 3.5 drive connector fit but it seemed to be that the bottom part of the connector is all ground so i didn't t
https://lh3.googleusercontent.com/proxy/mEyFCyFykqSnWiYpkVu32ZjMjqbbTkAOWJTfbC2k_gQP24ewBMf75rXixEJGn08WvLmy4x7pfcp_CT1_7vyJXHunhNScMQ
