XTIDECFG saving ROM
prime
Coventry, UK
Hi there,
In the XTIDE config / flasher program I can configure the settings of the XTIDE bios. I have done this however I don't see a way of saving the bios image back to a file so that I can later program it with a different flasher utility (lo-tech's flash in this case). Anyone know if it has this option and if so where it is hidden.
Cheers.
Phill.
Seems you can only save back to a loaded file, but doesn't seem to be a way of loading from the ROM on the card and then saving to a file.
Cheers.
Phill.
