Flamin Joe
Hi, got a bit of a strange one here.
I brought a replacement PCB some time ago for my Model F XT Keyboard to replace one which was giving the keyboard 301 error after my attempts to fix it came to nothing. After going through all sorts of fun getting it back together I was getting the 3B 301 keyboard error which is a stuck key but after many attempts I was unable to find which key was causing the issue. So I decided to test it with just the bare PCB carefully held in my hand to rule out any funny stuff with the PCB and that's where the weirdness starts.
If I hold it by the edges carefully not touching any of the pads the system will boot up fine and I can touch the various pads to confirm it's registering key presses. All good there.
If I put it down on the table, which by the way is a non-conductive wood surface, I start getting key presses??? Put it upside down (so it's the side your typing on facing the desk) and it's just the B key which is being pressed. Put it the otherside so the typing face is up and I get all sorts of keys getting pressed. Carefully pick it up from the edge and it stops.
I'm baffled as to why this is happening. I've cleaned both sides of the PCB with circuit a board cleaner so it's spotless but yet as soon as you put it on any surface it triggers the typing. Thinking maybe there's the possibility it's flexing causing these random activation of keys I held it carefully by the edges and gently flexed the board but nothing. I also tried a different cable from my other working Model F XT and it does the same thing.
At least now I know why I was unable to find the "stuck key" as it was obviously getting triggered by just being in the case but baffled as to why it's getting triggered in the first place. What am I missing?
