How common are ROM failures?
I recently picked up a later 5150 with a 256K motherboard. It had an AST Sixpak Plus and some sort of network/terminal card used when it was in the service of an airline. When I powered it up for the first time, a tantalum capacitor on a floppy drive popped and the power supply shut down. It's C36 here.
I unplugged the drive and that allowed it to power back up again, but of course with a 601 error and it didn't load BASIC. Instead, it had F600 and FC00 ROM errors, exactly like here. This makes me ask if it's pretty common for these to fail. I tried reading one of them, and it showed blank. The other could be read, but didn't match what was here even though the part numbers all matched the C1.10 versions.
I was able to write two replacement MCM68766 EPROMs and the system seems to work flawlessly now, well after replacing the floppy drive with a spare until I can order some capacitors. Also, I removed one of the Motorola EPROM and I replaced it with a Texas Instruments TMS2564, just to see if they really can be used. It worked fine, just the top two legs on each side hanging out of the socket.
