alejack12001
I need some help from the forum regarding configuring a Western Digital WD1002A-WX1 MFM controller for one MFM hard drive, ST251-1. The manual I have was written by Olivetti, which addresses a Superbios setting, a "G" setting, and "H" setting, which I don't have clue what G or H represent. I have the BIOS enabled. Picture of the board is shown below.
Apparently, there is a W6 setting where-by-which either an 8 head drive with RWC (???) is supported or 16 head hard drive supported (head select 3 as was shown in the manual). Right, now, I have this setting set to the 8 head because the drive has 819 cylinders and 6 heads.
At first, I had all the S1 jumpers set to be jumped 1-4 and it resulted in the same response as the following setting where I reset S1 to have jumpers only on pins 3 and 4 since according to table "H" that is the correct setting for the drive configuration. This "H" table is the configuration mentioned earlier and is the only one that seems to support the physical settings for the hard drive. With the settings whether the first or second, the displayed cylinders are 614 and heads 4 which are addressing an ST225 shown by Seagate's OnTrack.
BIOS Chip mounted to the card ahs the following number: 62-000094-002
Current settings:
W3 closed BIOS Enabled
W4 Pins 2 & 3 closed I/O Port address 320h
W5 hard-wired Pins 1 & 2 closed
W6 8-head hard drive w/RWC supported Pins 2 & 3 closed
W7 Hard Drive Interrupt is IRQ 5 Pins 1 & 2 closed
W8 Single controller setting, primary controller Pins 2 & 3 closed
S1 Jumpers 5-8 are open
S1 Jumpers 3 & 4 closed and 8 is open. According to table H the jumpers 3, 4 & 8 address drive 0.
So, how do I get the correct setting for the 819 cylinders and 6 heads?
Current settings:
