Hi every one!
I was the proud owner of an Atari PC3 back in 1987, all my friends had Amigas and they didn't pass a chance to tell me that their computers could both display more than 16 colors (at once) and had something resembling real music and sound effects. But I was very fond of my PC and started learning programming in GW Basic, moving to Turbo Pascal and then C++.
So I wanted to get that warm fuzzy feeling again and started looking for an 8088 machine, 5150 or similar, but seeing how rare and expensive they have gotten I started looking elsewhere and bid on a local auction for a PS/2 which I won. While waiting for it to arrive I started reading up on all things PS/2 related and to my concern found a great deal of posts about how problematic this machine is and its rare and proprietary components. But my conclusion is, that if you can live with the peculiarities its actually a very nice machine in a cute form factor with that special industrial eighties look.
Starting the machine when it arrived I noticed:
1. The screen (8504) was in perfect shape, its grayscale, but no burn-in and very bright and crisp image.
2. The floppy drive wasn't working - I have ordered components for a recap and will disassemble the drive and clean and lubricate it thoroughly.
3. The hard drive sounded weird and reported a 1790 error. "No problem" I thought, I will put in a CF ISA card instead seeing how rare these special IBM drives are. But after fiddling around with the machine reconnecting drives it just started to work. Don't know if the head got stuck over the years and just needed some exercise or the reseating of the cable did the trick. Now it works perfectly, and the drive is actually in very good condition with no bad blocks or anything.
4. The machine came with an Intel 8087 and a Siemens SAB 8086. I just ordered a NEC V30 for the fun of it.
I am now shopping for a color display preferably an IBM 8511, 8512 or 8513 but I am not very optimistic finding it here in Europe and I am not sure which ones where available as 220V/50Hz versions? Is it a realistic venture or should I just settle for a generic VGA/EGA CRT display?
Best regards
Martin
Best regards
Martin
