mikeyp
Hi all
Really weird issue today with my 5160. It's been working fine, no major issues, everything pretty reliable so far.
Today I went to put a 2nd floppy drive (Gotek with HxC firmware) in above the hard disk. Connected it up, turned off switch 7 on the motherboard, everything good to go you'd think. It booted first time just fine. Now, whenever I turn it off or press Ctrl-Alt-Del, it gives disk boot failure. Doesn't matter what drive, they're all the same. Original 360K Floppy, disk boot failure. MFM HDD, disk boot failure. XT-IDE, disk boot failure. Any one of the 3 on their own with the others removed, disk boot failure. The XT-IDE BIOS loads, I can select by pressing A, B, C, D etc, but all disk boot failure.
Here's where it gets really weird. Put in a floppy disk I generated with WinImage, I get the boot sector text with Gilles Vollant so it's clearly reading ok, it then says it's not a system disk, trying system disk and... disk boot failure.
If I leave it for 30 minutes and start it from cold, it boots fine. Reads all drives fine, until I restart.
I've just put switch 7 back on and taken the extra floppy out of the equation, back as it was and... disk boot failure.
Anyone got any thoughts on what now please?
