short story: irregardless of what I do, I cant get my dual p-pro system to work at an acceptable speed. Benchmarks @ 2.5 with memory throughput @ ~28mb/s. Regular Pentium comes in @ 147 and 70mb/s.
Long story: I just got in the voodoo 1 card for my "gaming" dual Pentium pro system and in attempting to install NT 4.0, I noticed it was taking FOREVER. I stopped it after EIGHT hours. I decide to run some benchmarks to see what was going on. Here is the "ideal" setup that I was shooting for:
Asus p65up5 motherboard with c-p6nd cpu card. (REV 1.41 and 1.2 respectfully)
512mb edo ram (8 sticks)
2x Pentium pro overdrives @ 333mhz
matrox G200 video card
voodoo 1 6mb
awe64 sound
3com 509b
IDE raid card LSI series 511
Naturally I pull everything to the bare essentials, and it still made no difference. re-setting the bios did nothing, nor did setting up the bios for "maximum speed". So I run some benchmarks too see whats going on, and this is the result:
http://i.imgur.com/fG51is.jpg
And for comparison, here is how my 386dx40 does.
http://i.imgur.com/5EfT7.jpg
changing video cards made no difference. Changing the ram made no difference. (tried 5 sets)
I change the processors to 200/1m's
http://i.imgur.com/tzwrm.jpg
Then to 200/256k's
http://i.imgur.com/rG4D7.jpg
So I test another board. This time its a dual socket 7 with a pair of 200's and 512kb of total cache. Same video card, same ram.
http://i.imgur.com/dlML8.jpg
You can see in the bottom right graph the cache working exactly as it should, a LOT different than the other board. Also, i know full well it says failed on the extended memory test, But that's a concern for a later day, as this board did this with EVERY set of ram that I have. (I'm running mem test right now to be sure, I THINK it has a bad socket)
I test a 3rd board, this time its a DIFFERENT p65up5. Its a rev 1.2/1.1 setup. it was NOT compatible with my 1mb chips but the scores were identical. I didn't bother to save any pictures of these.
voodoo 1 6mb
awe64 sound
3com 509b
Then to 200/256k's
