framer
What I'm doing is redoing a few vintage system and ended up with a left over 5160 case.
I had 1st selected an old Tyan 1564S with 32MB of RAM in the 1st memory bank and had it almost ready to button up then changed my plans. I took apart another tower that was setup using a Tyan 1564D with 256MB and setup for NT 4.0 server software and put that in the 5160 case. I had to use plastic stand off on the MB as the only hole that lined up was for the screw by the power connector. None of the other holes lined up but the standoff worked perfect. This board needs to be insulated from the case, so this mounting made that easy.
I had to cut off 1/4 inch on the back edge of the left bay over to the support, the whole front support had to go and widen the top system board support to allow more space over the board. I also added a HD bay under the right side by removing a support and drilling a couple of hold to attach a HD from the bottom. This board was 4 banks for memory "8 slots" , only bank 1 & 2 are accessible as there is no room under the left drive bay for memory sticks. It also restricts what you can put in the bottom left bay because the stick height is higher than the bottom of the bay.
I also made a couple of brackets to support 4 HH devices in the two FH bays.
It's up and running but will take another week to finish as I want all black color on the front. It's going to have a 40G IDE HD in that lower bay. This will be used for data and accessible from what ever OS that's used. 1 DVD writer, 1 3 1/2 1.44 FD and a front panel that allows USB CF SD card support. The last bay may have a duel 2 1/2 sata drive rack. I've ordered off ebay an IDE to dual SATA card that just plugs into the IDE port on the MB. The board has a USB 1.1 port but I added a PCI card that has two USB 2.0 9 pin headers. The video card is a ATI Mach64 with a 3DFX v1.0 board.
I tested the 1564S w/ 32MB using W2K using a CF drive. It worked better than I thought it would, a bit slow but doable. With the duel board and 256MB it should work fine. It should run win98 quite well also. That why I want a drive bay to swap OS.
I will also keep the NT4 server HD as I may want to use that later.
I'll post photos when done.
I hope it has that real retro look and a killer win98 machine.
framer
framer
