Here is a link, http://www.willegal.net/scelbi/8008-disassembler.c, to the “C” language source for my 8008 debugger/disassembler. Though it has been a while since the code diverged, the core 8008 instruction emulator is essentially the same as used in my Macintosh OS/X app. Some of the output could be cleaned up a bit and I want to add an emulated SCELBI cassette interface, but I think it has been pretty useful in creating and debugging 8008 software.
It takes 1 or 2 arguments, an Intel HEX file with the program to debug and an optional starting address (in decimal).
Here is a list of commands.
b – set break point
d – dump memory
r – run – note that unless you have a break point set, or the program encounters a halt instruction, there is no way to halt the program
s – step
n – next – steps over calls
h – display numeric values in hexidecimal (except for disassembly)
o – display values in octal
u – disassemble range of memory – use more readable format
a – disassemble range of memory – use format compatible with AS8 assembler
x – exit to shell
Thanks to Cameron Cooper helped me with the initial conversion of the step display to include instruction nmumonics.
Things to do – add support for emulated SCELBI cassette interface.
regards,
Mike Willegal
b – set break point
d – dump memory
s – step
x – exit to shell
regards,
Mike Willegal
