glitch Veteran Member Joined Feb 1, 2010 Messages 5,051 Location Central VA Oct 4, 2021 #1 I know everyone has been waiting on this for a while Prototype boards finally arrived this morning: Marked as reproductions, of course:
Agent Orange Veteran Member Joined Sep 24, 2008 Messages 6,612 Location SE MI Oct 4, 2021 #2 Pretty enough to hang on the wall.
glitch Veteran Member Joined Feb 1, 2010 Messages 5,051 Location Central VA Oct 4, 2021 #3 Ready for wiring! What's shown is pretty much the parts that will be used for the parts kit.
glitch Veteran Member Joined Feb 1, 2010 Messages 5,051 Location Central VA Oct 4, 2021 #4 Wired up! Set for default addressing (0x10 - 0x13, 20-23 octal) and RS-232 level shifting. We'll have to build another to test current loop: Washed up and in the drying cabinet now.
D deramp5113 Veteran Member Joined Mar 9, 2013 Messages 969 Location Dallas, TX Oct 5, 2021 #5 Looks great! Mike
glitch Veteran Member Joined Feb 1, 2010 Messages 5,051 Location Central VA Oct 5, 2021 #6 Done drying, IC sockets stuffed, bitrate selection jumpered: Wire wrap pins installed for the bitrate selection. The holes on the reproduction have been enlarged to accept a Mill-Max press fit pin; these aren't those because I can't find the samples Installed in the IMSAI for testing: It works!
