I was having trouble finding a serial board for my Altair at a reasonable price so I decided to build my own board. Here's a picture of it in its current state.
The 40-pin dipper is a SCN2681A DUART, which is a great device to work with. It's still missing the transceivers but that is coming along.
When I started to make the schematics I also decided to put in a socket for an EPROM (or as in this case a flash memory). I also opted for a two PLD (16V8 ) decoding and bus control solution. The EPROM is selected by the LS85 and the DIP switches to the left in the board.
Later I plan to add a floppy controller to the empty upper right section of the board (notice the conveniently placed 34-pin connector), but that is for another rainy day.
The 2681 has a 8-bit output port and a 7-bit input port that will be used to (among other things) control the /PHANTOM signal to be able to disable the on board EPROM if I should ever want to run CP/M on with this board.
/Pac
/Pac
