Vercus
Hello,
I just recently acquired two Northstar Horizons with a Heathkit H19 terminal. They came with several disks, and I've been trying to figure out what I need to do to get one of them to work. When I power the system up, the floppy drive spins, but it doesn't boot, even after trying several different disks. I even swapped out the floppy drives and systems, and both do the same thing.
I can only use one system at a time right now, as I am short a memory board- it caught fire
I have a whole box of old hard sector floppies, but I'm assuming I can't write those with a modern DOS PC and a 360K drive, correct? What would be the best way at getting a known good CP/M or N* DOS boot disk? I've found some software on the internet, but have no idea how to write it.
On the upside, I have TONS of manuals for this thing! Just about everything I could imagine is discussed in there. I'll definitely pour into them and see what I can dig up. Still, it seems to me if the drive is spinning and a disk is in it, something should happen, right?
Thanks in advance,
Jon
Thanks in advance,
Jon
