Hi All,
I'm not a super EE guy but I learn what I need to and try hard to do things right and understand what I'm doing for the most part. I picked up an Altair 8800 about 6 or 7 months ago that had been gutted and rewired for a different bus (non-s100) and had a regulated PSU (not one that could actually work with S100) and the front panel had been reconfigured in about a dozen and a half spots. I spent maybe 50 hours or so restoring the front panel to match the schematic (AFAIK) and re-attached the original S100 bus to it. I also rebuilt the original PSU as I found the original PSU board and transformers.
So now I have what should be a working Altair 8800, however I'm at the part where I can't figure out what to debug next.
With just 2 cards: MITS 8080 rev0 and MITS 4k dynamic ram rev0
What works:
Examining an address does move the address LEDs.
Examine/next does increment address LEDs correctly.
Run/Stop/Step/Reset all seem to function correctly.
All LEDs are functional in that they do turn on so I don't have any burned out or misconnected.
What does not work:
D0-D7 are constant on.
It looked like the base address of this dram card is at 4096 so I tried starting there with deposits but still nothing. I'm assuming sold D LEDs indicates that RAM is not working.
Could someone please tell me where to look next or what debugging I could do to help get more info? I'm just not sure what the next steps are. I have not checked to see if the capacitor values on the front panel have been changed to match the spec of the MITS dram card, though that should only cause intermittent deposit error IIRC and would not result in solid D indicators.
Thanks!
What works:
What does not work:
Thanks!
