Announcement
Collapse
Forum Rules and Etiquette
Our mission ...
This forum is part of our mission to promote the preservation of vintage computers through education and outreach. (In real life we also run events and have a museum.) We encourage you to join us, participate, share your knowledge, and enjoy.
This forum has been around in this format for over 15 years. These rules and guidelines help us maintain a healthy and active community, and we moderate the forum to keep things on track. Please familiarize yourself with these rules and guidelines.
Rule 1: Remain civil and respectful
There are several hundred people who actively participate here. People come from all different backgrounds and will have different ways of seeing things. You will not agree with everything you read here. Back-and-forth discussions are fine but do not cross the line into rude or disrespectful behavior.
Conduct yourself as you would at any other place where people come together in person to discuss their hobby. If you wouldn't say something to somebody in person, then you probably should not be writing it here.
This should be obvious but, just in case: profanity, threats, slurs against any group (sexual, racial, gender, etc.) will not be tolerated.
Rule 2: Stay close to the original topic being discussed
  • If you are starting a new thread choose a reasonable sub-forum to start your thread. (If you choose incorrectly don't worry, we can fix that.)
  • If you are responding to a thread, stay on topic - the original poster was trying to achieve something. You can always start a new thread instead of potentially "hijacking" an existing thread.
Rule 3: Contribute something meaningful
To put things in engineering terms, we value a high signal to noise ratio. Coming here should not be a waste of time.
  • This is not a chat room. If you are taking less than 30 seconds to make a post then you are probably doing something wrong. A post should be on topic, clear, and contribute something meaningful to the discussion. If people read your posts and feel that their time as been wasted, they will stop reading your posts. Worse yet, they will stop visiting and we'll lose their experience and contributions.
  • Do not bump threads.
  • Do not "necro-post" unless you are following up to a specific person on a specific thread. And even then, that person may have moved on. Just start a new thread for your related topic.
  • Use the Private Message system for posts that are targeted at a specific person.
Rule 4: "PM Sent!" messages (or, how to use the Private Message system)
This forum has a private message feature that we want people to use for messages that are not of general interest to other members.
In short, if you are going to reply to a thread and that reply is targeted to a specific individual and not of interest to anybody else (either now or in the future) then send a private message instead.
Here are some obvious examples of when you should not reply to a thread and use the PM system instead:
  • "PM Sent!": Do not tell the rest of us that you sent a PM ... the forum software will tell the other person that they have a PM waiting.
  • "How much is shipping to ....": This is a very specific and directed question that is not of interest to anybody else.
Why do we have this policy? Sending a "PM Sent!" type message basically wastes everybody else's time by making them having to scroll past a post in a thread that looks to be updated, when the update is not meaningful. And the person you are sending the PM to will be notified by the forum software that they have a message waiting for them. Look up at the top near the right edge where it says 'Notifications' ... if you have a PM waiting, it will tell you there.
Rule 5: Copyright and other legal issues
We are here to discuss vintage computing, so discussing software, books, and other intellectual property that is on-topic is fine. We don't want people using these forums to discuss or enable copyright violations or other things that are against the law; whether you agree with the law or not is irrelevant. Do not use our resources for something that is legally or morally questionable.
Our discussions here generally fall under "fair use." Telling people how to pirate a software title is an example of something that is not allowable here.
Reporting problematic posts
If you see spam, a wildly off-topic post, or something abusive or illegal please report the thread by clicking on the "Report Post" icon. (It looks like an exclamation point in a triangle and it is available under every post.) This send a notification to all of the moderators, so somebody will see it and deal with it.
If you are unsure you may consider sending a private message to a moderator instead.
New user moderation
New users are directly moderated so that we can weed spammers out early. This means that for your first 10 posts you will have some delay before they are seen. We understand this can be disruptive to the flow of conversation and we try to keep up with our new user moderation duties to avoid undue inconvenience. Please do not make duplicate posts, extra posts to bump your post count, or ask the moderators to expedite this process; 10 moderated posts will go by quickly.
New users also have a smaller personal message inbox limit and are rate limited when sending PMs to other users.
Other suggestions
  • Use Google, books, or other definitive sources. There is a lot of information out there.
  • Don't make people guess at what you are trying to say; we are not mind readers. Be clear and concise.
  • Spelling and grammar are not rated, but they do make a post easier to read.
See more
See less
VG Vector 1++ floppy drive power connector
Collapse
X
  • Filter
  • Time
  • Show
Clear All
new posts
    I am about to restore a Vector Graphic 1++ that can hold two internal floppy drives that I do not have. They are supposed to be Shugart SA400 compatible (as the manual states) and I believe the controller calls for the floppy drives to use 16 sector hard sector floppies. The power connectors for the floppy drives, however, are not what I am familiar with. The manual also talks about a "mini-floppy power supply P.C. board". Would I be correct in thinking I can't just replace the connectors with a normal floppy power connector and run it?
    Here's a pic of the connector I am speaking of:
    Any help is much appreciated.
    Maintainer of http://vintagecomputer.ca
    #2
    I think those were for Micropolis drives, which have a pinout close to, but not exactly matching an SA400.
    Here's the service manual for the 1015/1016
    Note that the early units are 100 tpi 77 cylinder units, not 48 or 96. Micropolis did make 48 and 96 tpi drives later.
    Reach me: vcfblackhole _at_ protonmail dot com.
    Comment
      #3
      Yes, those are the Micropolis drive power connectors. The dives are single sided and were used with 16 hard sectored floppies. You'll find "Mod-I" or "Mod-II" within the model number on the drive. Mod-I is 35 tracks at 48tpi, and Mod-II is 77 tracks at 100tpi.
      The mini power supply board provides regulated 5v and 12v for the drive from the computer's main supply. I assume that regulator board is on the other end of that power harness you pictured, or are there just bare wires at the other end?
      The key to your next step is what type of floppy controller is in the system. Sounds like it may be the Micropolis FDC (or the Vector branded version of the Micropolis FDC). Post a picture of the FDC when you can.
      Mike
      Comment
        #4
        Thanks guys. I hadn't taken the cards out yet because I was going to order floppy drives, if needed, and then clean it up but that was a Doh! moment The controller would tell me more. I thought I'd look at the manual first but it says Shugart SA400 drives. I'm pretty sure it's the right manual along with a few other goodies including Micropolis documentation
        That said, you guys are right. They floppy controller is Micropolis.
        I do have a couple of Micropolis dual drive enclosures with drives so I'll see what they are. The connection for the floppy power cables goes to the big cap and some voltage regulators so this looks okay:
        Oddly enough, this came with an IMSAI CPU board installed.
        The manual says it should be a Z-80 board but I don't think I have that. I do have an loose IMS Z-80 board though. Interesting machine so far. It does have a lot of cards in it but I'll explore those further a little later. Sadly, the fan got broken in transit so I need to find a replacement.
        I should look in the manual in case the previous owner included the Vector Micropolis documentation.
        Comment
          #5
          Looks like the controller is strapped at the standard address of 0xF800. It has the jumper in place near the top left corner of the board that tells disk driver software that the CPU is running at 4mhz. This jumper is used by software so timing loops are correct for 4mhz vs 2mhz processors. I'm curious - look closely at your 8085 CPU board, can you determine its clock speed?
          The FDC does not have a very common mod (and later, a standard mod) that turns the drive motor off after a few seconds of inactivity. Instead, the drives will behave more like AC powered 8" drives in which the hub motor turns all the time and the head loads and unloads.
          MDOS and Lifeboat CP/M 2.2 for Micropolis will work on 8080/85 machines. Vector Graphic CP/M 2.2, however, has Z80 specific instructions in the BIOS. I can help you get you up and running with MDOS and CP/M on this machine whenever you're ready.
          Mike
          Comment
            #6
            Thanks Mike. I spent a little time cataloging what's in this system. The IMSAI MPU card is an 8080. I also have a PROM card that has MDOS on it.
            Take a look at the following link for some pics of what's in this Vector 1++ (and my clean out handiwork ) http://vintagecomputer.ca/?post_type=computers&p=143
            I appreciate the help. Now I have to see what Micropolis drives I have.
            Comment
              #7
              In the documentation I have is a document about the VG Monitor that's on the PROM/RAM card. At least I know that it is the "CV" version which is set up for "Bitstreamer Serial in" and "VDM-1 out". I have a couple of I/O cards and now I know what to hook up. I also know the command to jump to the "Extension PROM" which I assume is the MDOS PROM with monitor command "E", I think.
              Still haven't powered it up yet but I'd like to read about the cards first and make sure they are configured properly.
              Comment
                #8
                Looks like the 2nd PROM is actually an MZOS PROM, not MDOS. MZOS was a VG product that they eventually abandoned for the more powerful MDOS (Micropolis DOS) and then CP/M. The MZOS PROM contains the disk I/O routines for MZOS and resides at C400-C7FF.
                Mike
                Comment
                  #9
                  Thanks Mike. I though that was a typo but I found the MZOS user guide along with MDOS and CP/M manuals. Here's a letter in my Vector manual. Funny how everything sounds revolutionary and then disappears
                  On a related note, I did find an almost identical replacement fan on eBay http://www.ebay.ca/itm/131401338710. Same make and model number; the Rotron Whisper model WR2A1 but the fan hub wasn't green . I didn't realize these were 120 volt fans. Once I get this, I'll install and try to power it up.
                  I have a 9" Sanyo monitor so I'm probably okat there but I'm not sure what I would use as a keyboard. Do you think my "homebrew keyboard" here would work? http://www.vintage-computer.com/vcfo...board-computer My only other parallel keyboard is an IMSAI KBD-1 and I'd like to leave that one alone.
                  On another related note, I found the Vector Graphic mailing list and am now subscribed. I've started to read through the archives. Haven't read about anyone having a Vector 1 yet.
                  Comment
                    #10
                    Most VG activity on the list seems to be about the MZ era as opposed to the earlier machines. I have a Vector MZ and a Vector 3. I have a number of Micropolis drives and a few Tandon drives. In fact, I have my Sol-20 running Lifeboat CP/M on two Micropolis Mod-II drives.
                    I've seen MZOS, but never paid much attention to it until your posts. I find the Northstar DOS to MZOS upgrade path very interesting. I've recently bought a Northstar FDC and some SA-400 drives. My plan is to get Northstar DOS and CP/M running on the Sol-20 with a Northstar controller (a very common configuration) someday soon. Once that is working, it now seems a very logical progression will be to get MZOS running on my MZ. I may need to get a copy of that PROM!
                    Mike
                    Comment
                      #11
                      My PROMs are your PROMs. I just don't have a programmer that can read 2708 PROMs and I don't really want to jury-rig a power supply and twist some pins to read it. Do you have a programmer that will read 2708s?
                      Comment
                        #12
                        I can read the PROM here, but it may be simpler to write a short program that dumps the PROM out through the serial port. Even on a bare-bones machine, this simple of a program could be typed in with the "P" command of the VG ROM monitor.
                        Mike
                        Comment
                          #13
                          Update on my progress:
                          I finally received my replacement fan and installed it. I fired up the CPU board, PROM/RAM board and Video board and got a rolling * prompt after reseating some chips. It acted like the <center> key was stuck but I had no keyboard attached. I had to install my Bitstreamer board (not connected to anything) to get a * prompt with a single blinking cursor. At this point, I am looking over the Bitstreamer documentation to figure out how the wires/connectors are configured.
                          I don't have any memory boards or the floppy controller board installed yet but I think it's progress if I should be seeing a * prompt.
                          Comment
                            #14
                            I've hooked up a PC with TeraTerm to be able to use a keyboard via serial port through the VG Bitstreamer card. I can type and see the output on the video display connected to the Solid State Music VB1B. I can enter commands through the VG 2.0 monitor (the * prompt) but I can't get MZOS to come up. I think I am supposed to be doing this through the "B" command (Jump to Bootstrap loader) or "E" Jump to Extension PROM at C400 but I see a pattern of characters on screen. I can dump C400 and there is data there until C7FF so it looks like the MZOS PROM is there.
                            Screen shot of pattern here:
                            Any help is appreciated. I will reach out the the VG group if there is anyone there with a VG Vector 1.
                            Comment
                              #15
                              Yes, MZOS is booted with the E command to jump to the MZOS ROM at C400. Do you have an MZOS disk in drive 0 and does the drive come to life when you execute the E command?
                              Comment
                              Working...
                              X
