NeXT
An AltairClone has zero consideration for adding an S100 bus inside the extremely empty case if one so desired, but nothing says that with a LOT of diodes you could isolate the lamps and swiches and toggle between the onboard emulation and control of a real S100 machine. (or just disable the emulation completely) That being said, I'm not exactly sure how the front panel interfaces with the bus.
Referring to this photo I can see a number of lines interface with the bus directly and others feed into the CPU card.
Referring to this photo also indicates the front panel PCB isn't entirely passive.
Also, are there layouts of something like an 8-slot S100 bus somewhere I could use to send off to a board house for etching? I see photos of various people and their own designs but no actual layout files.
