Nama
I have my IMSAI up and running with a 3P+S card jumpered to mimic a 2SIO card and John Garza’s M84 monitor at F000.
However I decided to try to build it up as a Processor Tecnology ‘Subsystem B’ system.
Subsystem is a collection of Processor Technology cards that come together to form a complete system:
- 3P+S Parallel/Serial card
- VDM-1 Video card
- GPM RAM/ROM card
I’m missing the GPM card but have both the VDM-1 and 3P+S card.
Instead I thought I could build it up using a EconoROM and one of my PSS RAM16 cards to mimic the GPM card.
The GPM card is unique in that it contains the Cuter Monitor rom at C000h, and 1k of RAM starting right after cuter at C800h.
Following the 1K or RAM is another 1K of video RAM for the VDM-1 card starting at CC00h
(All cards I believe are working)
I hooked up my system in the following way.
- 16k RAM @ 0h - 3FFFh
- EconoROM containing 2k cuter @ C000h to C7FFh
- 16k RAM @ addressed to C000h - FF00h, then jumpered for a 2k hole a starting at C000h (for Cuter) and another 1k hole at CC00h (for the VDM video RAM).
Unfortunately I could not get this setup to work. I was able to get the video to reset, and the cursor to display in the upper left corner, but there was no '>' prompt, and following the cursor was some random characters.
I tested to see if my setup looked correct. I could read and write to all the RAM locations (taking into account the holes), and I could see the Cuter ROM where it should be.
I wasn’t sure how I should go about organising the PHANTOM lines on all the cards, or even if I needed to worry about them.
I played with this setup for sometime, with no success.
In the end I took it back to my original M84 monitor setup, but would really like to give SUBSYSTEM B setup another go.
Anyway, I was just wondering if anyone knew what I was doing wrong, or had any insight into my problem.
Thanks
Phil
- VDM-1 Video card
- GPM RAM/ROM card
Thanks
Phil
