snuci
Nama and I were conversing through PMs about replacement Sol 20 screws. I thought it might be good to show these in case anyone else was interested.
Nama bought some replacement screws from this eBay auction as I have done in the past and for his Sol 20, they wouldn't fit. I have two different case models within my Sol 20s where the replacement screws would fit in one but not the other. I told Nama I would take some pics so here they are in case anyone else is interested.
This is Sol 20 #1 and it has a small hole. You will notice there is a hole in the blue top cover.
This is Sol 20 #1 with the replacement screw in place. It is a little loose but once screwed down completely, it holds in place properly.
This is Sol 20 #2 that has a different hole. The top case slides over the screws that can simply be loosened since it is not a simple hole.
On Sol #2, I have the original screw fastener. This is what it looks like holding down the top cover.
This is a picture of both screws side-by-side. There is definitely some diameter difference.
Nama, you probably have a Sol 20 like my bottom one, correct?
I should check the serial numbers to see which one is older. There are at least two different case types. I have two of the first and I bought screws for both so I don't know what the original screws for that model looks like. I have one of the second but it has the screws so we know what that looks like. If anyone has case style #1, I'd love to see a picture of the screws.
Anyway, hope this helps.
