Roland Huisman
Today I've picked up an old TEI S100 system. It has a 8085 CPU. The previous owner used
it for a decade as an external floppy drive on an IBM compatible machine... How low can you go.
Well it probably saved the machine it's live...
The machine has a very, very nice construction. A pleasure to look at.
Unfortunately the floppy controller is missing. There are only a CPU , I/O and memory board.
The drives are MPI B52 models. DSDD, that is why they could work on an IBM compatible...
I found out that Tei had an FDC-2 and FDC-3 floppy controller card. The FDC-2 has
an 1771 and the FDC-3 an 1791. I would expect that the machine had an FDC-3 controller
because only this controller could use the full capacity of the floppy drives...
But FDC-2 or FDC-3, it doesn't matter. I can't find any software for this machine.
Does anyone have software images for these Tei machines?
This is a bit special... A constant voltage transformer in this computer...
You can see the AC capacitor at the arrow. http://www.circuitstoday.com/cvt-constant-voltage-transformer
Thanks in advance!
Regards, Roland
Thanks in advance!
Regards, Roland
