JonB
Hi
I am now starting to look at an S-100 box I acquired recently. First check is the PSU - I measure +18, -18, +9.5 volts on the three power rails, unloaded. I think these are OK. The PSU is a typical early linear supply having 1/2 wave rectification (the +-19v rails are supplied by a single piece bridge rectifier, whereas the 9.5v rail looks to be supplied by two separate enormous diodes of obviously high current rating. There are three very big electrolytic caps on the board - 95,000uf 15v and two 5500uf 45v. I've removed the cards and plugged it in, it's humming along nicely giving the unloaded readings above.
I'm thinking of leaving it like this for a while - a sort of soak test. Agreed there is no load, but I'm not ready to plug boards into it just yet..
Cheers
JonB
Cheers
JonB
