I have a Tandy 1000RL Hard drive. Been a while since I got it, and I finally plugged it in, and the HD needed a tap to start spinning, but t appears to work, at least as far as I can currently test. Current problem is that I do not have a keyboard that works with it. It has a PS/2 connector on it but non of my keyboard work. Keys either do not work, or what I press does not match what is shown on the screen. I am assuming this is some oddball signaling. Any thoughts on getting a modern ps/2 keyboard working with this?
So the HD is obviously on its way out, what are my options for replacing this? it is an XT IDE I believe.
Thanks in advance!
Thanks in advance!
