So I got a 1400HD in good cosmetic shape for next to nothing, with the obvious disclaimer of "Don't have the power brick, can't test." Incidentally, I DID have a power brick from a 1400HD that I had years back but have long lost.
But alas, powering up just illuminates the backlight (sometimes) and all three keyboard lock LEDs light up steady; that's it.
Now, years back, with the old 1400 HD I had, I tore it apart because of a bad HDD, and found that the PSU will put out voltages without being connected to anything. Naturally these are the expected normal voltages of +12V, +5V, and probably -12V (used by the modem.) I even used this to power an AT board as a silly experiment back then.
Anyway, with THIS one, I've tested all the pin connections coming off the PSU, and about half are "dead", and the ones that work test out +5V. So it appears to me that the 12V side is the "dead" part. This was further hinted because the PSU has a 12V cooling fan on it which was not turning, clearly unpowered. I'm not an electrical engineer and am not too familiar with circuits more complicated than "Battery-Switch-Lightbulb", but I can use a DMM and traced 12V at least as far as the battery connector and a couple regulators.
Of note, CLEARLY somebody has messed with it before. There were two screws missing from the case and fuse "F1" has been directly soldered across on the underside!
Could this be the classic capacitor leak situation? Does that make sense as a possibility? Some of them do look a little sour on their undersides. I ordered myself a set of assorted electrolytic capacitors with ranges of parts I have seen on the PSU, as well as a capacitor tester (unless you guys just recommend I replace them all anyway while I'm poking around.)
And this is probably a long shot, but does anyone happen to have a pinout of what the PSU pins voltages SHOULD be? Or would be willing to open a 1400 to test them out? Of all portables I've ever opened, this one definitely is not difficult at all (just the screws on the bottom, and you can lift the case), so if you have a 1400 and are willing, it would be much appreciated...
