I've had a 1000TL for a couple of years but just recently found a suitable ISA VGA card at goodwill. the video card seems to work fine and i see the boot process.
no hard drive in the 1000TL, only a 3.5" floppy. and no floppy in the drive.
it immediately gives me a drive A critical error, press R to retry or C to cancel. i get stuck in a loop here.
shouldn't the 1000TL do something beyond this point with no floppy, no hard drive? any suggestions on what to check? looks like power is supplied to the floppy via the ribbon cable, as there's no other connections to it.
thank you.
thank you.
