gp2000
A classic trick on the Z-80 to save a little bit of time and space is to use one of these instead of "LD A,0"
A very good replacement as long as alteration of the flags is not a problem.
However, in the name of robustness, a more modern "Trust, but verify" technique is preferred.
While heeding Knuth's words ("... premature optimization is the root of all evil (or at least most of it) in programming") it seems fair to optimize that approach a bit.
On the other hand a Monte Carlo approach may be called for.
Ah, but those familiar with the Z-80 will have spotted a bug. The top bit of R register only changes when loaded. Easily fixed by elegantly mixing in the deterministic approach:
Should flag register changes be a concern we can borrow a technique from the MIPS processor which forces one of its registers to always be a zero value. After brief consideration, C is the obvious choice.
While C may be needed for the odd LDIR this is no problem as it will be 0 after it executes. Now a quick
will do the TRICK. And it generalizes to all the other 8 bit registers. I hope these ideas will help improve your Z-80 programs. Have a nice DAY.
XOR A
SUB A
TOZ: DEC A
JR NZ,TOZ
TOZ: ADD A,A
JR NZ,TOZ
TOZ: LD A,R
JR NZ,TOZ
TOZ: LD A,R
ADD A,A
JR NZ,TOZ
- HL is too important addressing memory and doing 16 bit stuff.
- DE is HL's understudy, ready to take over at a moment's notice (and an EX DE,HL).
- DJNZ rules out B.
- C pretty much looks like a 0 already.
LD A,C
