TRS-80 Model 4 - Power on with blank screen
Win9xGuy
United Arab Emirates
Hello everyone
Have TRS-80 Model 4 that powers on with blank screen. Floppy light red for few second on booting. CRT tube no heating or noise.
What I did:
Scrolling brightness/ contrast, not helping.
Holding break key, not helping.
CRT folk on place.
Any suggestion?
Is your Model 4 a Gate Array Model or Non Gate Array Model. (You can tell by the RS-232C
Port. If the RS-232C port connector is sticking straight down (towards Desk) it's a Non Gate
Array Motherboard. If the RS-232 Connector sticks towards the back of the Computer it is
a Gate Array Version.)
That should get us to the correct Video Board.
Larry
so if you know "CRT tube no heating or noise." then I will assume you already opened the computer.
disconnect the PSU (if a single one) and take it off the disk drive bracket, then reflow all the pins of the connector without forgetting the extra 2 that bring power to the video board, reassemble and power up and test 2 pin connector to see if power is leaving the psu for the video board, seethe technical manual below for where/how much should be coming out of pins.
M4 NGA https://drive.google.com/file/d/1eZGOEsckPiBtBDKcMdNR7AjF1KvaXg_T/view?usp=sharing
M4 GA https://drive.google.com/file/d/1AzZ7RNVQ5R12ZYtcc2kvUyfb5No38FTO/view?usp=sharing
Larry
Greetings Patrick
As you mentioned, the problem was with PSU. Pins had dry soldering.
Check picture.
Problem with CRT solved.
Thank you very much! :)
I sent reply, but not published yet.
Hi Patrick
As you mentioned, the problem was with connector pins in PSU.
Attached a picture before reflow.
Thank you :)20210410_194541.jpg
