falter
I'm working on a Netronics keyboard and terminal I got recently and am at the point where I need to power it up. It did not come with a power adapter, but the case seems to indicate 8-10vac. IIRC Netronics for whatever reason preferred AC rather than DC power supplies for their equipment.
Just as a precaution.. is there anything I need to be wary of with AC vs DC? I have a 10vac 1200ma adapter here.. I was going to remove the barrel connector (the keyboard requires a 3.5mm), and temporarily wire it directly in.
