Schematic for Infoton Vistar II/HZ terminal ?
zippysticks
UK, South East
Folks,
anyone have one please ?
I have found the technical users manual on bitsavers but can't find a schematic.
Thanks in advance.
Folks,
Thanks in advance.
Can you dump the firmware and take pictures of the board(s)? it is early enough that it may not even have a microprocessor
fun! dynamic shift register memories. does it have a keytronic keyboard? it's old enough that they were probably still using reed switches in the keyswitch assemblies
They appear to be. If you look on the bottom you should see two leads for the reeds and sometimes they cut a hole in the PCB in the middle and you can see the glass bulb.
