The computer is a Dell OptiPlex GXa. The computer sometimes doesn't turn on. Nothing changes other than the passing of time. I can come back the next morning and it will turn on. This morning, however, it didn't. What could be the problem?
Do you get anything kick then immediately stop ? ie CPU fan
Timo W. said:Test a different PSU. Be aware that DELL used PSUs with an ATX connector but not ATX pin-out for some time. If that's the case here, using a generic ATX PSU will kill the mainboard.
