Mike_Z
Yesterday a neighbor was getting rid of an old Win98 machine, HP8650C. He asked me if I wanted it, since I'm a collector of odd stuff (according to the neighbors at least). I thought that I'd make a DOS machine out of it, since I needed a 5.25 floppy drive. This machine has a 20 gb HD and a 3.5 FDD. I pulled it appart and cleaned it out. Wiped the HD and used FDISK and Format to get a working DOS 6.22 in it. Gee, I hadn't done that in a while, kind of forgetten some stuff, but it came back. I checked the BIOS and it supports 2 floppy's and 360K and 1.2M 5.25" are options. The 3.5" works so I was going to leave it in and make the 5.25" A:\. Well first I had to find a multi FDD cable in all my old stuff. I connected up the drives and set the BIOS and neither of the drives would work. Pulled the 5.25 and the 3.5 was fine. Figured that the Panasonic JU455 was not too good. I then cleaned the rails and the heads and everything seemed clean and smooth operating. Tried it again, same thing. So I pulled my XT apart and installed the Panasonic in it and the FDD works like a charm. I could read/write/ format everything. Then I thought that maybe the new machine didn't need the terminating resistors, the Panasonic has a 150 ohm chip, so out it came. Now on boot the Panasonic motor starts but the LED never comes on and the stepper doesn't move the head at all. When I ask for A:\, the motor starts but nothing else and I get a "seek error reading A:", yet I know that the stepper works and the rails are free. So I tried changing the BIOS settings and no dice. I'm kind of out of bullets trying to get this thimg to work. It just occured to me, I'll try adding "DRIVPARM" to the config.sys and see it that works any better. Anyone have any ideas, short of getting another floppy drive?
By the way, I'm new with this forum, how do you get spell check to work on this? Kan't seam ta foind ait.
Thanks Mike
Thanks Mike
