Unknown Card
If I had to guess I'd say it was a tape controller. I remember a few from back then that had support for both internal and external QIC tape drives.
Erik
Its definatly a data aquisition board, the pots on top are for calibrating the input signals. The middle connection is probably for DIO inputs (ribbon cable to external plug) and the one on the end is the A/D and D/A part.
I have a bunch of ISA data aquisition cards, if you dont want them I'll take them. Without the apropriate cables and interface boards there isnt much you can do with them.
