I'd like to try using multiple controller cards to control various drives simultaneously (hard drives, floppy drives, CD-ROM, magneto-optical drive, tape drive, whatever). I know that the following things exist for data flow, and they must be kept separate for everything to function.
IRQ channels
DMA addresses
I/O addresses
If my mouse, for example, uses 3F8h, that is 3F8 hexadecimal = 1016 decimal = 1111111000 binary. Does that address then just refer to a specific RAM byte? Or is it a group of bytes? How many bytes are in the group?
IRQ channels
DMA addresses
I/O addresses
- How many different IRQ channels are there? Sixteen, numbered 0 to 15.
- How many different DMA addresses are there?
- How many different I/O addresses are there?
- Are DMA addresses, RAM addresses, and I/O addresses referring to the same thing?
- Does every device I put into the computer need a unique IRQ channel?
- Does every device I put into the computer need a unique DMA address?
- IRQs seem to be generally controlled by jumpers on expansion boards. Are DMA addresses controlled by jumpers? If not, how are they controlled?
