'********** MONITOR.BAS - shows how to detect the display adapter type
'Copyright (c) 1992 Ethan Winer
DEFINT A-Z
DECLARE SUB INTERRUPT (IntNum, InRegs AS ANY, OutRegs AS ANY)
DECLARE FUNCTION Monitor% (Segment)
TYPE RegType
AX AS INTEGER
BX AS INTEGER
CX AS INTEGER
DX AS INTEGER
BP AS INTEGER
SI AS INTEGER
DI AS INTEGER
Flags AS INTEGER
END TYPE
DIM SHARED InRegs AS RegType, OutRegs AS RegType
SELECT CASE Monitor%(Segment)
CASE 1
PRINT "Monochrome";
CASE 2
PRINT "Hercules";
CASE 3
PRINT "CGA";
CASE 4
PRINT "EGA";
CASE 5
PRINT "VGA";
CASE ELSE
PRINT "Unknown";
END SELECT
PRINT " monitor at segment &H"; HEX$(Segment)
FUNCTION Monitor% (Segment) STATIC
DEF SEG = 0 'first see if it's color or mono
Segment = &HB800 'assume color
IF PEEK(&H463) = &HB4 THEN
Segment = &HB000 'assign the monochrome segment
Status = INP(&H3BA) 'get the current video status
FOR X = 1 TO 30000 'test for a Hercules 30000 times
IF INP(&H3BA) <> Status THEN
Monitor% = 2 'the port changed, it's a Herc
EXIT FUNCTION 'all done
END IF
NEXT
Monitor% = 1 'it's a plain monochrome
ELSE 'it's some sort of color monitor
InRegs.AX = &H1A00 'first test for VGA
CALL INTERRUPT(&H10, InRegs, OutRegs)
IF (OutRegs.AX AND &HFF) = &H1A THEN
Monitor% = 5 'it's a VGA
END IF
InRegs.AX = &H1200 'now test for EGA
InRegs.BX = &H10
IF (OutRegs.BX AND &HFF) = &H10 THEN
Monitor% = 3 'if BL is still &H10 it's a CGA
ELSE
Monitor% = 4 'otherwise it's an EGA
END IF
END IF
END FUNCTION
