hjalfi
I'm looking for a reasonable assembler and linker for 16-bit DOS which will generate small mode exes. I need to something which I can legally distribute --- it's for my Cowgol compiler; currently it'll cross-compile to DOS but I want it to run natively (see http://cowlark.com/cowgol/).
So far the best options I've found are the Arrowsoft Assembler, which is public domain but for which no source is provided, and the VAL linker, which is also public domain and while it has source code it's uncompilable. But there's a vast amount of ancient and obscure software out there. Does anyone know of anything else? In particular, I'm only assembling a single source file, so if there's an assembler which will emit EXEs directly, that'll save me a lot of grief.
Thanks!
Thanks!
