Eudimorphodon
Inspired by a recent thread on the worst x86 CPUs ever made I've dusted off an old mini-ITX thin client I've had untouched in my garage for at least a decade and decided to see how well it works as a strict, according-to-Hoyle DOS computer. (No Windows 95+.) The machine is based on one of the first EPIA revisions that uses a Via Apollo PLE133 North Bridge (SDRAM memory) with Trident-based VGA and an AC'97 sound codec that also includes some rudimentary Soundblaster hardware compatibility. The build at this point includes only what's on the motherboard, a single 512MB DIMM, and a PATA-to-SD converter with a 64GB card that DOS can't see most of.
After some fits, starts, and a 15 minute interlude where I decided the machine had definitively died and was about to strip out the DIMM and chuck it in the trash(*) I seem to have the machine pretty much working. But I have some questions/concerns about exactly how the hardware is set up.
My first crack at getting things running involved DOS 6.22 and MEMMAKER. Memmaker ran through its probing of upper memory and decided that the only unoccupied region suitable for UMBs was a 32k slice from D800-DFFF. (It complained very loudly that EMS wasn't a possibility because there was no room for the page frame.) Obviously 32k isn't anywhere near enough to be useful on a machine like this.
(Soundblaster emulation relies on a 38k TSR to do FM synthesis, only the digitized sound is aliased directly to hardware, and to make matters worse the packet driver for the onboard Rhine Ethernet also occupies 39k; an annoying amount considering the NE2000 driver on the Tandy 1000 is only 5k...)
I switched to PC-DOS 7.01, and instead of bothering with its memory setup wizard I tried setting up UMBPCI.SYS instead. When run without any arguments this driver apparently uses similar probing critera to MEMMAKER because it likewise only gave me 32k at D800-DFFF. Reading the manual it marks any area that doesn't return all zeros as occupied, so I blindly started playing with the /I switch to include larger and larger blocks of Shadow RAM.
Right now I have the machine booted up and seemingly working with the following line in config.sys:
DEVICE=C:\VIA\UMB\umbpci.sys /I=cc00=efff
Which results in mem /c showing the expected 144k of upper memory:
The base of CC00 was derived empirically by observing the following: When set to C800 the machine would boot fine into text mode, but running any kind of graphics software would crash to a garbage screen. This didn't happen with the base at D000, and splitting the difference seems fine as well. (However, the only software I've tried so far uses standard CGA/EGA/VGA modes, so I definitely can't say I'm not still sitting on top of part of the video BIOS.) So presumably if I tell it to use the 16k between C800 and BFFF I'm squatting on top of ROM, which would generally be discouraged.
Anyway. 96K seems like a heck of a lot of memory for a video BIOS, so I'm wondering if there's any sort of tool for looking at the Option ROM area of more modern machines like this and identifying what the contents of "occupied" areas are in more detail. Unfortunately I couldn't find anything remotely like this in the manuals for the motherboard. Maybe as long as it doesn't crash it doesn't matter so I can stick to just "try and fit"-ing it until I see a problem, but I'd still love to know what I'm stepping on. Unfortunately Checkit3, the tool that's usually really useful on the old machines, seems a little out of its depth here. I'm hoping some of that ROM is, I dunno, a huge wad of bloated PXE boot code that's deactivated anyway.
If anyone else is running a rig like this and has some tips for best setting up a pure DOS environment on such a "legacy free" PC I'd love to hear them. It would be nice if this thing had an ISA slot so I could set up a real Soundblaster card. Is there a PCI soundcard that can actually do FM synth in hardware under DOS? The FM synth from the TSR is a little wonky, but it does work, I guess. I'm curious about how compatible it's going to be with programs running under DOS extenders. (If at all.)
(* footnote: that "I almost threw it away" thing: this board has never had a fan on the CPU heatsink so I've always assumed it was a low power Eden board, but now I'm thinking some wanker harvested the fan off it before it ended up in the trash pile I stole it out of. It was running *hot*. It's been stable since I added a fan, fingers crossed.)
Modules using memory below 1Mb:
Name Total = Conventional + Upper Memory
SYSTEM 13,776 (13K) 13,760 (13K) 16 (0K)
HIMEM 816 (1K) 816 (1K) 0 (0K)
UMBPCI 160 (0K) 160 (0K) 0 (0K)
COMMAND 2,656 (3K) 2,656 (3K) 0 (0K)
CTMOUSE 3,104 (3K) 0 (0K) 3,104 (3K)
DOSKEY 1,152 (1K) 0 (0K) 1,152 (1K)
VIAFMTSR 38,928 (38K) 0 (0K) 38,928 (38K)
FETPKT 40,208 (39K) 0 (0K) 40,208 (39K)
FREE 700,976 (685K) 636,928 (622K) 64,048 (63K)
Memory summary:
Type of Memory Total = Used + Free
Conventional 654,336 17,408 636,928
Upper 147,456 83,408 64,048
Reserved 312,320 312,320 0
Extended (XMS) 67,043,328 65,536 66,977,792
Total memory 68,157,440 478,672 67,678,768
Total under 1Mb 801,792 100,816 700,976
Total Extended (XMS) 67,043,328 (65,472K)
Free Extended (XMS) 66,977,792 (65,408K)
Largest executable program size 636,832 (622K)
Largest free upper memory block 63,664 (62K)
Available space in High Memory Area 14,192 (14K)
PC DOS is resident in the high memory area.
