NeXT
I'm trying to write out a set of Lisa disks and I'm finding that while I am downloading them through Internet Explorer 5 and Netscape directly to a classic mac they are unstuffing from bitsavers as the dreaded "file". The images themselves still work if you fired them over to a Lisa via serial and wrote them using BLU and they are all .image and .dc42 images so they should work with Disk Copy 4.2 but because they don't have a file type attribute, Disk Copy refuses to see them as valid images. I am currently not setup to write every disk out over serial and the only recommended program so far that tweaks attributes (FileType) does not work on 8.1. How can I fix the attribute so I can make Disk Copy work with them?
