Hugo Holden
I have never owned an IC tester. Specifically the types of IC's in my vintage computers I tinker with are 74 series TTL types, but there others, cmos etc and of course various types of memory IC's. Normally I test the IC's in their actual circuit with the scope. But, still, I was thinking of getting an IC tester to add to my assortment of lab equipment.
It seems there is a plethora of different testers out there, including home projects based on Arduinos and various PIC's, to stand alone units. Yet others which require use with a computer and run a software package and link to the computer with a usb cable.
And on top of this, the price range is very interesting, for example, this Leaper unit which tests 74 series and 4000 series cmos, it is a stand alone unit but it is over $800 AU, which seems a lot for a small unit, & I don't know if it can do any memory IC's.
I wonder why the Leaper unit is so costly, is there something very special about its design or construction that I'm overlooking, making its price in fact reasonable ?
http://www.farnell.com/datasheets/1816934.pdf
https://au.element14.com/leap-electr...SMART-SHOPPING
Are there any recommendations for stand alone IC tester units, that users on this forum have been happy with and regard as a good value workshop asset ?
